m50 belt w/out ac or power steering
  • 02stu
    • Jan 2005
    • 872
    I am running no power steering and no ac so I need a belt that is much smaller then stock. If I measure the belt path with a string how much should I take off the overall length to account for the tensioner, an inch? Thanks
    Stu
  • cheades
    • 632
    Well you don't need to take the A/C into account as that runs off its own belt. You would need to do some measuring to see how far out the ps pump is and pulley diameter for an accurate length to remove.
    • EtaSport
      • 2853
      PM the fast one! to get the belt size. He has it, I think its around a 55 inch 4 rib or something like that.
      Old and improved:
      • 02stu
        • Jan 2005
        • 872
        It doesn't look like you can remove the ps and make the belt work since the tensioner tighens the belt where it wraps around the ps pump. I'll pm that member and see whats up, thanks
        Stu
        • EtaSport
          • 2853
          It works, you just have to route it a little differently.
          Old and improved:
          • Jason89i
            • Sep 2004
            • 875
            yea, it works.
            i have it deleted on my 86 m50 (w/ manual rack). i cannot find the receipt for the belt though...sorry.
            cheers, jason
