S50 swap write-ups?
  • Ball325
    • Sep 2004
    • 187
    S50 swap write-ups?
    i had a bunch on my old computer and it broke and now i cant seem to find them again. I have the one from this site but i wanted to review many of them since the one i got from this site doesnt have any wiring write ups and such.
    the ones i have seen are sort of vague on Motor mounts and setups using the E36M3 transmission. DONT TELL ME TO SEARCH I have been for a while but ive had better luck just scanning through the stickied thread to links. Im the kind of person that wont start on this until i know exactly what i have to do and what i need and get it all at once.
    thank you
  • Brew
    • 3060
    E36 engine mount arms, e28 535i engine mounts.
    I believe all of this info is in the first page of the DOHC thread.
    '91 318is
    • Ball325
      • Sep 2004
      • 187
      that was like one of my questions but there are more. I know there are tons of sites with good write ups but i cant seem to find them. Anyone have links
      • ///Mpressive
        • Mar 2006
        • 192
        There too many variables to just follow some write-up. Tell us your application and what you want in it. After you have read the Comprehensive Swap thread, then ask specific questions. We will help you.:D
        08 Toyota FJ Cruiser, Rock Sliders, Mostly Stock for now, parts on the way....
        97 Toyota Land Cruiser FZJ-80, Front Bambi Basher w/ 2x100w PIAA's, mostly stock
        • RVA e30
          • Jan 2006
          • 140
          there is not just one way to go about this engine swap. but the stickied thread got me through the entire swap without a problem.
          • Ball325
            • Sep 2004
            • 187
            yeah i read it once like 2 months ago but im not doing the swap till this winter. I should take notes while reading it.
            • Kilomph
              • Oct 2004
              • 599
              An admin should go through and filter out all the useless babble.
              • RVA e30
                • Jan 2006
                • 140
                agreed, if that were the case then it would be a LOOOT shorter
                • Ball325
                  • Sep 2004
                  • 187
                  yeah there is alot of information there but also alot of useless stuff as well.
                  If someone could sort that thread it could be much more useful
                  also my set up ill be running an S50b30 out of an 95 M3, im not sure about the ecu but im using the transmission as well.
                  I think im going to go with the 325ix Booster, unless the 320 booster is a better option. the modification required isnt a problem i have a machine shop. I understand i can use the stock motor mount arms but need e28 mounts, Also i understand wiring and such but i hate doing it so i might just buy the treehouse adapter, its one less thing for my to worry about. the motor will have a full harness and intake and everything. since its coming out fo my buddies car and hes putting in an s54, he has an e36 m3.
                  • equate975
                    • Jun 2004
                    • 3382
                    Rollin' with a Geistkuchen
                    • e30_kid89
                      • Apr 2006
                      • 489
                      agreed. and keep the info as up-to date as possible.
                      • Ball325
                        • Sep 2004
                        • 187
                        thanks my bookmarks are getting respectable again. And i found an article i printed out like 3 months ago. its a good one
