S52 GUYS. Throttle Body and Cable inquiry
  • Yezus_Krys
    • Feb 2016
    • 80
    Ok so I'm swapping in my S52. I'm gonna run it OBD1 and have an M50 manifold. Now do I need to get the M50 throttle body with an adapter and E34 cable or will I need an E36 cable with the S52 TB?
    Sent from an Abacus
  • flyboyx
    • 8371
    the m42 cable works just fine.
    im not sure what you mean by adapter. also, i can't recall, but i think you can use the obd2 throttle body on your obd1 manifold if you don't have the earlier one. just get rid of the traction control butterfly.
    Gigitty Gigitty!!!!
    • Unearth078
      • May 2008
      • 2623
      if you plan on OBD1, you run OBD1 components. I did use the e34 cable for throttle, and e36 cable for cruise control.
      Originally posted by Lof8
      4 doors allow you to transport more whores.
      therefore, their value is much greater.
      Down to: 89 aw2 332i/4/5 , 70 Sahara 2002
      • NC325iC
        • Mar 2004
        • 6565
        e34 cable didnt fit well for me so i am using the e36 cable
        • Yezus_Krys
          • Feb 2016
          • 80
          Ok so today I made the M50 throttle body from an E36 work. It was a lil tedious pulling it apart to make the E30 cable fit just right but it works.
          As for the adapter plate I was referring to. The S52 TB has a 'gapped ring' around the hole on the mani side. Without the adapter it will cause vacuum leak. That's with M50 mani to S52 TB.
          Sent from an Abacus
          • GG///M3
            • Dec 2004
            • 327
            Sent from an Abacus
            Who sells the adapter?
            • ZekeTheSneak
              • 1562
              m50 throttle body, i cannot recall the throttle cable but i think e34, mine has a bend in it and works perfect.
              • Yezus_Krys
                • Feb 2016
                • 80
                They're on eBay. Here's one https://www.ebay.com/itm/110453718950
