Temp gauge pegged on red when key is on
  • e30m20TurbO7
    • 1203
    So when I turn the key on the temp gauge just goes all the way to the red even when the engine is off. If I turn the key off and I hit the gauge it goes back to blue. Is power going to the gauge ? When the key is on?
    I had a wire short in my engine harness a month ago that went to the relay because I had a cap off the relay to test to see if it was working and it arched it self on the body burning up a wire to constant power in the harness, this is a e36 harness obd1 m52 swap. The temp gauge worked fine before I burned up a wire.
    I fixed the wire going to the relay and noticed the temp gauge was doing this after. If I unplug the connector from the temp sensor there is no change the gauge just goes to red when the key is on.
    Does it mean it has low voltage of to much resistance ?
    Where do I start ?
    Cluster ?
    Sensor ?
    Si board ?
    C101?
    Confused on what to do
