Are these cams weird? They seem weird.
  • kronus
    • Apr 2008
    • 13032
    Curious if anyone can read this cam tag and tell me what it would behave like in an m50tu or a s52? (I can stick them in either..)
    The short story is they were sold to me as stock-spec s52 regrinds, but going by what I can understand from the specs, that is not what they are. Seller has unfortunately since disappeared. I'm honestly pretty surprised I got them at all..
    cars beep boop
  • pazi88
    • Sep 2015
    • 584
    Seems to have almost exactly same specs as s52 stock cams so you got what you paid for. So put those into m50.
    • kronus
      • Apr 2008
      • 13032
      awesome, thanks for the sanity check.
      I also called the regrinder (Crower) and they said basically the same thing. Kind of weird that nothing matches the published specs, but I also called Rebello and they said that everyone measures cams differently and that those sound pretty much like stock S52 cams.
      cars beep boop
      • AllydNYC
        • Aug 2013
        • 350
        Ooo, your username looked familiar, then I looked at your signature. I like your YouTube videos, keep up the good work. I like relaxing on the couch and watching them.
        ...Sorry, off topic!
        E30: '91 318is - M52/ZF320 | Azev A 16X7.5 | H&R Race/Bilstein | Completely refreshed suspension/brakes/drivetrain
        An Associate/Bachelors degree is America's most overrated product
        • pazi88
          • Sep 2015
          • 584
          The s52 intake cam has 252 degrees and 10.2 mm of lift. Yours have 257 degree and 10.64 mm, so it's pretty close. Nothing that would make noticeable difference. For the exhaust I have found different specs but it should have 240-244 degrees and 9,7 or 10,2 mm of lift. Yours have 244 degrees and 9.82 mm of lift so it also very close.
          But you are right about measuring the cams differently. Some manufacturers give their cam specs from 0 mm of lift to 0 mm (the degrees I was talking previously). But some European manufacturers give the duration from 1 mm to 1 mm lift. And in your spec sheet they also give the duration from 0.050" to 0.050" of lift which is from 1.27 mm to 1.27 mm.
          Thanks a lot!
