S52 OBD1 - Bucking... MAF or ... ? Help!
  • Tekals
    • Nov 2012
    • 24
    Hi,
    I've swapped an S52 OBD1 into my e30 in August. Engine has had a few things done to it beside the OBD1 conversion. Dinan throttle body, M50 intake, euro 3.5" MAF, sharks injectors, Dinan computer and tune. I've also changed the spark plugs and new crankshaft position sensor.
    Motor ran fine for a while then i started having heavy bucking (like the engine cuts out completely for a fraction of a second) when hitting potholes and just became worse with time eventually became undrivable. Disconnected the MAF and the car has been running fine but really rich.
    I've purchased a new MAF as I thought it was my problem. Changed it, but it didn't fix the bucking issue. I've started thinking what else changed after the swap. The headers didn't fit so I had a custom exhaust made and they relocated the oxygen sensor. It used to be after the downpipe only picking up 3 cylinders. Now it is much further back (middle car) and is right at the H pipe intersection. Could this affect the signal and cause issues??
    Any ideas? Diagnosis tests suggested?
    Thanks guys.
  • Poopie
    • 295
    Could be bad grounds. My bucking issues are from the disintegrating maf connector.
    • Jaker
      • Oct 2013
      • 234
      Do you know this for sure? Have you fixed/replaced the connector and the issues went away? My MAF connector has seen better days, but didn't think the issues I'm having were because of the connector. My issues are only when the engine/engine bay are cold. Once things warm up, the car drives fine.
      • Tekals
        • Nov 2012
        • 24
        I can confirm my MAF connector is perfectly fine. might have to follow the wires and look for a bad connection maybe. It could explain why it started by bucking only when hitting bumps in the road
        • sweet3
          • Oct 2012
          • 751
          I just posted this is someone else's post as well. They were also having problems that might be related to the mad.
          If you have a K&N filter or something similar, try put the MAF sensor connector on the top and see what happens. Seemed to do the trick for me.
          PNP Adapter Harness Wiring for M52TU, M54, S54, M60, M62, M62TU, S62, M50, S50, M52, S52 & MORE
          • Tekals
            • Nov 2012
            • 24
            Tried that, seems to have helped a bit but didn't solve the issue, thanks tho
            • sweet3
              • Oct 2012
              • 751
              Ah, have you tried cleaning it since you had it the other way? Spray some brake cleaner and blow it with air. Don't let the brake cleaner sit too long though.
              Just pulling at straws now lol. This might not make any difference.
              Hope you get it figured out.
