Will any ZF 320 work?
  • BMW_TUNER
    • Jul 2006
    • 1379
    I have found a 5 speed behind a 530i (2001) will it work with my clutch setup? My current setup is for a G260 with an S50 flywheel and pressure plate and I also just purchased a Neue Motorsport adapter to work with a ZF and my driveshaft.
    1989 332IS -S-Fiddy Four-Some weight removed.
    5 lug E36 M3 Brakes Coilovers and LTW's and No ABS.
  • exhaust
    • Jun 2015
    • 411
    I'm 90% sure it should work. Check part numbers on RealOEM. The six speed from the S54 bolts up to an S5x just fine and those are M54 variants to an extent.
    • BMW_TUNER
      • Jul 2006
      • 1379
      Realoem shows one part number that fits everything e36/e46/e39 Z3 etc, so I guess it will work. Just hoping someone could verify.
      • pazi88
        • Sep 2015
        • 584
        Yes every zf320z will work. They are all pretty much the same. Allthought they can use different oil so remember to check the label if you change the oil.
        • BMW_TUNER
          • Jul 2006
          • 1379
          Sweet
