can anyone point me to a good OBD2 wiring writeup?
  • Slay89
    • Feb 2017
    • 15
    it is a e39 harness and the plug that is missing is a X6011
    • haaken675
      • Sep 2016
      • 601
      did the e39 harnesses not have an x20 connector? I checked the part numbers I could find on the harness itself and it matched up with a 328 harness.
      • emripires
        • Dec 2015
        • 74
        this sounds like a huge undertaking for you.. I would probably abandoned this if I were you.
        • sweet3
          • Oct 2012
          • 753
          If the OP counts 19 wires, it couldn't be the x6011 that is missing.
          Could you take a more detailed pic of the harness?
          PNP Adapter Harness Wiring for M52TU, M54, S54, M60, M62, M62TU, S62, M50, S50, M52, S52 & MORE
          • haaken675
            • Sep 2016
            • 601
            ill get a full picture this evening.
            • haaken675
              • Sep 2016
              • 601
              im starting to wonder if all three of the pictured plugs were cut off giving me what i have. That looks like it could be more like it. Ill get better pictures this evening though to try and figure it out.
              • haaken675
                • Sep 2016
                • 601
                I found this image on my phone. I know its not the greatest, but it shows the wire harness laid out at least. I will get detailed pics when I am home this evening.
                • J0dylan
                  • Jan 2017
                  • 10
                  Thats def not an e36 328is obd2 harness, or it's a really chopped up one. It doesn't have the injector rail with the front o2 connectors on it, which would normally be attached right about where your bundle of cut off wires is sticking out.
                  • haaken675
                    • Sep 2016
                    • 601
                    crap, I was thinking the injector harness was a separate peace...I am going to light this guys world on fire.
                    • haaken675
                      • Sep 2016
                      • 601
                      So just to guess, this harness is probably a waste to try and use in my case?
                      I've been trying to return it but the guy that sold it is being an ass...
                      • haaken675
                        • Sep 2016
                        • 601
                        Looks like this is an e39 wire harness...
                        And here is the rest of it:
                        I have been looking at this as it was an e36 harness the whole time which definitely threw me off...So now i'm not sure if it is worth working on this or just buying a new one...I already bought a c101 to splice into it.
                        • J0dylan
                          • Jan 2017
                          • 10
                          I'd get a new one, sucks but that one has been hacked into pieces and is way too much hassle to try and fix. It doesnt even have half of what should be there. I just did this part of my swap with a 98 328is auto harness if you find one similar I can probably point you in the right direction as far as what you need to do to it to get it working.
                          • haaken675
                            • Sep 2016
                            • 601
                            working on getting the asshole that sold it to me on ebay to refund me...Guess its time to look for a new harness.
                            • EulB30
                              • Jun 2011
                              • 73
                              haaken what part of FL are you in? If you're local I could give some insight.
                              Alpina B6 2.8/1 Project
                              http://www.r3vlimited.com/board/showthread.php?t=345025
                              Frankenstein Turbo Swap Thread [On Hold]
                              http://www.r3vlimited.com/board/showthread.php?t=255606
                              • haaken675
                                • Sep 2016
                                • 601
                                I live in the Tampa Bay area.
