M52B28 Swap- No Crank No Start
  • eThirT
    • Jul 2016
    • 48
    I have finally reached the point of starting my swapped E30. I have checked everything and found that the starter is not getting power when the ignition is turned on. I can't figure out why and how to fix the issue. I'm using a ZF 320Z, M3 flywheel, and M3 starter. Can anyone shed some light on this? Thanks!
  • emripires
    • Dec 2015
    • 74
    was it automatic?
    • eThirT
      • Jul 2016
      • 48
      Originally posted by emripires
      was it automatic?
      It was.
      • emripires
        • Dec 2015
        • 74
        Originally posted by eThirT
        It was.
        PM me, I'll sort you out.
        • amcp
          • 488
          I'd say share the info and post it up. Cant hurt to spread the word.
          • eThirT
            • Jul 2016
            • 48
            I couldn't agree more. I wish I would have known earlier. It turns out because my car was originally an automatic I needed to do the wiring shown at the bottom of this link: http://www.rtsauto.com/bmw-e30-trans...tic-to-manual/
            • Mwishlist
              • Jul 2013
              • 505
              That is definitely one way to do it. The thread I linked below is a little confusing but if you go through it I think it makes sense. Basically the auto wiring is just added for the auto cars, you can easily bypass it with a few plugs over the pedals as opposed to the wiring from the RTS write up. This is what I used and it worked like a charm without having to cut any wires etc.
              Thank god, R3V was getting boring since the ginger kid wrecked his car. - Stonea
