S50 loud ticking
  • cbouchez
    • May 2007
    • 2789
    S50 loud ticking
    Why does it tick so loud when warm?
    Thank you for your input.
    Follow my IG @bouchezphotography
  • Jaker
    • Oct 2013
    • 234
    My 1st guess would be slightly low oil level. I keep mine filled up to the top mark on the dipstick (sometimes a little over that). If that doesn't fix it, maybe oil is too thin (what weight oil are you using?).
    • cbouchez
      • May 2007
      • 2789
      Oil level looks good -
      LIQUI MOLY SEA 5W-30
      • M3PO
        • May 2012
        • 537
        Sounds like a lifter to me. How long as the engine been running since the swap? Mine did this right after I installed it because the lifters bled down from the engine sitting. The procedure is apparently to hold it at 3K for 3 mins to pump the lifters back up.
        • kronus
          • Apr 2008
          • 13025
          agreed on lifter noise
          cars beep boop
          • exhaust
            • Jun 2015
            • 411
            Seems like thin oil too. Run 15w-40 and a half quart over recommended.
            • cbouchez
              • May 2007
              • 2789
              It's been running for a few weeks-
              3K for 3 minutes? really?
              • cbouchez
                • May 2007
                • 2789
                I have an E34 dipstick on my S50 - Do I have to go over the mark on the stick?
                • M3PO
                  • May 2012
                  • 537
                  Yep, that worked for me. It seems a little scary but mine sits at 3750 for extended periods of time on the freeway at 80 mph so it's not that different, just no load.
                  I have the E34 dipstick also and have always filled it to the full line.
                  edit: That has worked for me twice actually. The second time my head cracked so I disassembled and cleaned all of the lifters before putting them in the new head so I had to do it again.
                  • cbouchez
                    • May 2007
                    • 2789
                    Thank you - I'll top it off and try it.
                    • exhaust
                      • Jun 2015
                      • 411
                      Completely agree with this.
                      • cbouchez
                        • May 2007
                        • 2789
                        Top it off- I'll drive home today and try what you are suggesting. I'll report back
