Can anyone confirm for me which pilot & throwout bearing for g260 and e36 clutch
  • haaken675
    • Sep 2016
    • 601
    Hey guys. I have been searching and searching for my answer and am at a bit of a standstill I am planning on using my g260 with the e36 clutch, pressure plate, and lightweight flywheel I have which from my research should work. I have the matching e36 throwout and pilot bearing.
    I remember reading somewhere that I may need to use a g260 throwout bearing or pilot bearing, potentially both. can anyone confirm which combo I need?
    I was hoping to start putting the motor in this weekend and I am already tired of buying duplicated parts.
    Thanks
  • haaken675
    • Sep 2016
    • 601
    no?
    • MaxBell
      • 1391
      You can use the E30 one, as I did.
      If you have the deep bellhousing G260, you can use Sachs P/N 21511204525 which is a 30mm bearing and will make up the difference.
      More info here: http://www.r3vlimited.com/board/show....php?t=109919&
      REMEMBER: Be safe and have fun is Rule Number 1.
      The Epic Unbuild of Clint Eastwood
      • haaken675
        • Sep 2016
        • 601
        my car is an '87 is, so I believe it is a "shallow" bellhousing. Do you need the e30 pilot bearing as well? I ask because I have a throwout bearing and pilot bearing that came with my clutch kit, but they are for the e36, and I don't know how to cross compare if they are the same or not. Surprisingly google doesn't understand my question, lol...
        • raj
          • Oct 2013
          • 100
          I swapped a 24v into an 87 is (G260) using:
          - Pilot bearing for M20 (11211709934)
          - Clutch kit from 24v
          The throwout bearing for E30 and E36 is the same. Pro-tip: you can use RealOEM to check applications for any part: http://www.realoem.com/bmw/enUS/partxref?q=21517521471
          • haaken675
            • Sep 2016
            • 601
            Thank you! I guess I should have checked realoem, but I have gone through so many lately I didn't even think to look for some reason.
