Oil Pressure Light on E30 S52
  • pazi88
    • Sep 2015
    • 584
    #31
    Originally posted by sweet3
    When you say that your oil light is on, is it on even if you rev it up a little bit passed idle? Even mine flickers when the engine is warm at idle. I believe thats just because the original m20 and the s52 operate at different pressure when at idle.
    There is not set limit or programmed value for oil pressure in e30 itself. The sensor in oil filter housing is just a switch, that activates at certain oil pressure and lights up the oil pressure warning. It's not oil pressure sensor that can sense different pressures. So if you guys use the oil pressure sensor that came with the engine, and not one from m20. It will trigger at correct oil pressure. If your oil pressure light is flickering, you have too low oil pressure (or the sensor itself is broken).
    • Sh3rpak!ng
      • Jan 2014
      • 2667
      #32
      Running it for a few mins won't get the oil up to temp enough to really be able to bleed off the lifters. I recently cleaned my lifters (pain in the ass btw) and bled them before installing. The car was all clickty clack until I drove it around and let the oil get hot. By the time I got home, probably a 20 min drive, it was normal.
      Also, I thought that while 5psi idle is low, it's not world ending. I always thought as long as you have some pressure at idle it's ok. It's far more important to have the right pressure increase with rpm.
      Did you up the oil viscosity and test again?
      Originally posted by ForcedFirebird
      We run Liqui Moly 10w60 in them (comparable to the later OE Catrol).
      Glad to hear that, I just went up to the 10w60 liqui moly as well since I still get a bit of lifter tick after thrashing the car at autox.
      Shadetree30
      • sweet3
        • Oct 2012
        • 752
        #33
        Yes I still use the s52 sensor. The light never came on in the e36 while it was running (the light was a functional light lol)
        PNP Adapter Harness Wiring for M52TU, M54, S54, M60, M62, M62TU, S62, M50, S50, M52, S52 & MORE
        • MaxBell
          • 1391
          #34
          SOLVED
          The engine block was disassembled and the S52 oil squirters were not in the bottom end. They're little misters that spray oil up under the pistons.
          I took the crank out, but them in and buttoned the motor up again.
          REMEMBER: Be safe and have fun is Rule Number 1.
          The Epic Unbuild of Clint Eastwood
          • 328ijunkie
            • May 2007
            • 3961
            #35
            Eeek. Who did the rebuild?
            Check Us out on Facebook
            Full Product Line Tuning
            • Sh3rpak!ng
              • Jan 2014
              • 2667
              #36
              WOW, glad you found it. That's scary
              Shadetree30
              • MaxBell
                • 1391
                #37
                A place in Toronto, Ontario. Refused to warranty their work as well. V frustrating.
                • e30rapidic
                  • 2167
                  #38
                  Originally posted by e30rapidic
                  were the oil squirters removed but not replaced?
                  Originally posted by MaxBell
                  SOLVED
                  Hey, I was right! ;)
                  '87 325ic, powered by S50.
                  • MaxBell
                    • 1391
                    #39
                    Thanks again for the help! :)
