I'm having an issue with this idiot light not turning on when it comes to starting the car. This is what I've done so far. I place a test light on D+ of the alternator and it does turn on and then off once the car starts..So the alternator works. I traced the blueish wire all the way to the connector behind the instrument cluster, again, with the test light it works.. Next I swapped the idiot light with a known working light and there was nothing wrong with the idiot light.
took the whole cluster apart and analyzed the traces on the circuit board and applied + and - voltage and the idiot light does turn on. I followed the trace from wire connector socket to the bulb and then it goes back to the same wire connector socket. So I looked at the wire connector and see that it the return trace matches a green wire on the wire connector. So basically. On that same wire connector behind the cluster, in comes in a bluish wire goes to the idiot light and then returns to that same wire connector to the green wire.. But this green wire has + voltage with the ignition on and so does the bluish wire. So the bulb is receiving + voltage on both sides which is why it's not turning on. It use to work.. open to any input ...This is an e30 turbo s50 m3 btw..Thanks..
