Sorry I'm getting back after a while. So I removed the fuel rail and while I cranked, gas was spraying so injectors are firing. Any ideas??
FIXED! Fuel+spark= No start??
Try a known good ECU or an unmolested 413 Red label. In these situations where everything seems good, it is the DME a lot of the time.
If you have fuel spraying, spark, cranking, and a good crank sensor (OEM, not cheap China shit), it should at least try to start.
How are you sure you have spark?Comment
Your video isn't working for me.
Just because you can see a spark does not mean that it will run. I had this happen with my M20. I could see the spark but it wasn't strong enough to fire. Condition of your plugs? Coil boots good? Have access to another set of coils?Comment
Plugs are new. Boots are good. Try this video.
After some deep thinking in the shower, I thought to myself and wondered if I had enough compression? Turns out the cylinders are all like 20 psi :( Gonna pull valve cover off to check timing and report my findings.Last edited by ykarabala; 04-21-2017, 10:51 PM.Comment
