Uk M52 Supercharge build
  • AtlantisTouring
    • Nov 2014
    • 3
    Hello all!
    i'm in need of some advice as engines are not my area of expertise and i'm struggling to find the answers i need :(
    Im in the process of doing a super charger on my m52b28, before i go ahead and fit the kit on i want to get some engine work done on the engine to try future proof it.
    I want to change the following..
    Head refresh
    Head gasket for a thicker one
    ARP Head stud Kit
    ARP conrod Bolts
    Main bearings
    Piston rings
    I just want to know, whether the oem spec rings would be good enough or should i look into an upgraded set of rings?
    The Supercharger kit is A ECS tuning v2 vortech charger but later down the line i'd like to up the PSI with a smaller pulley.
    Could anyone shed some light on the following please?
    Thanks !
  • gart
    • Jul 2012
    • 295
    I'm no supercharger expert but I would suspect OEM rings to be fine for this set up, and also not sure about a thicker head gasket. Under the lower SC boost I'm again just speculating with 0 research that you might not want/need to lower the compression with this set up. Interested to hear what others say.
    89 325 cabrio in progress m52tub28 swap
    99 540it
    86 Volvo 240 wagon
    99 Cherokee
    13 Passat
    • M3PO
      • May 2012
      • 537
      That all sounds fine to me, including the stock rings. A friend of mine makes 650 WHP on a turbo M52 with just head studs.
      • AtlantisTouring
        • Nov 2014
        • 3
        Thanks for the input guys!
        Good to know im on the right track!
