Main relay issues
  • equate975
    • Jun 2004
    • 3382
    Main relay issues
    Im having issues with my main relay. I checked the bentley and I am supposed to get a constant voltage between the red wires pins 30 and 86 all the time, I am not. Where do these wires end up going so I can make sure they are connected properly?
    Also, what relay model is the main relay supposed to have? I have a green one I have 6136-8373700 in there which does not seem right.
    Rollin' with a Geistkuchen
  • DEV0 E30
    • Oct 2004
    • 8904
    The 3 relays? Shouldn't matter what color.
    2 are 4 prong, 1 is a 5 prong however.
    • Rev Engineer
      • Jan 2006
      • 162
      According to the Bently, the red wires are powered all of the time. They go to the B+ terminal which I believe is the primary battery connection under the hood.
      • equate975
        • Jun 2004
        • 3382
        Yeah, I was doing it wrong. I think I have the wrong relays in right now, but I cant confirm the models that should be in the main, o2, and fuel pump. Anyone know the P/N for them?
        • Rev Engineer
          • Jan 2006
          • 162
          I'm pretty sure the fuel and o2 relays are interchangeable, unless one has a higher contact rating - they are both electrically the same. The main relay has 5 prongs. I'd be interested to know too, if the fuel and o2 relays are different. Have you checked realoem?
          • equate975
            • Jun 2004
            • 3382
            Everyone says that, all ym relays are 5 prong and the main relay and o2 are the same, fuel pump has a different one. If I swap the fuel pump and the main relay like I think it should be, the car wont start,
            • Rev Engineer
              • Jan 2006
              • 162
              Check the Bently again. The main relay is 5-prong and the fuel and o2 are interchangeable 4-prong relays. You can also look down into the socket to find the one that is 5-prong.
              • Rocla
                • 922
                Tried out 3 different relays for main(white), didn't work.
                Seems it has a diode inside and can't be replace by "normal" realy.
                Current:
                BMW 320i 2d 2.0 m20 -88
                BMW 325i Cabriolet 2.5 m50 -88
                BMW 316i touring 1.6 m40 -90
                BMW 320i 4d 2,2 m54 -01
                • aeryk7
                  • Oct 2005
                  • 616
                  Low Voltage to the DME/Main Relay ...So this is your code right!
                  Supposedly this has to do with the alternator. I didnt have a snorkel on my alternator and the light came on , i went online and people said this was the alternator. I put a snorkel on my alternator and the code went out , then i made a CAI w/ heatshield which kind of deleted my snorkel then the light came back on. Still have the code and the car still is very strong.
                  253rwhp
                  My Vids(OLD)
                  http://www.youtube.com/user/aeryk7#p/a/u/0/hS4ZAzSdUdY
                  http://www.youtube.com/user/aeryk7#p/u/2/C-0hnV2k_xU
                  • smokenbaby
                    • Jan 2006
                    • 9
                    The 5 pin relay is your Injector relay. The 5th pin is the switch pin to turn the Pump back on while cranking. What I found when I did my E30 2.5 conversion was that pin 86 on the pump relay had 12v backfeed when it should be ground. All I did was removed the standard wire going into the relay block for pin 86 and ran a new ground wire. Car started up and has been running sweet. I also reconfigured the standard wiring in the block to allow me to use off the shelf relays from any Auto Parts store. This means instead of using a NZ $60 BMW 30 amp relay I am using a NZ $12 Narva 30 amp relay with a 30 amp Inbuilt fuse. As for the O2 relay, My car doesn't run an O2 sensor so can't help there.
                    only the dead see the end of war
                    • equate975
                      • Jun 2004
                      • 3382
                      I have power to the main relay.
                      ALL MY RELAYS have 5 pins, but the o2 and fuel pump plugs have 4 wires going to them, the center pin is not used.
                      The o2 and main relay are the same, the fuel pump relay is not. If I swap the fuel pump relay and the main relay the car wont start.
                      • equate975
                        • Jun 2004
                        • 3382
                        I know that, but the bentley dosnt have the part number for the relay that should be in there.
                        • equate975
                          • Jun 2004
                          • 3382
                          86 should have 12v not ground. Thats what the bentley shows.
                          • equate975
                            • Jun 2004
                            • 3382
                            http://www.realoem.com/bmw/showparts...61&fg=25&hl=75
                            #1 is what I have for a fuel pump relay.
                            #17 is my main relay and o2
