What x20 wires at minimum are needed to run a m52 engine?
  • scarecrow
    • Apr 2013
    • 45
    Planning on doing a non bmw (240sx) m52 obd2 swap. Was wondering what wires at minimum are used to run the engine. I will be doing some research on wedophones but if you guys have any input that would be great.
  • 328ijunkie
    • May 2007
    • 3961
    I can help with the DME side of things. As far as what wires at x20 need to make engine run goes: if you handle the FP wiring external, just one ignition trigger wire is all that's really needed to make it run.
    Check Us out on Facebook
    Full Product Line Tuning
