Grounding
  • 968Reckless
    • May 2013
    • 1095
    Grounding
    So I'm in the finals stages of my swap. Motor is in and wire harness is attached. I'm wondering where exactly all the grounds should be. I know the m20 was grounded from the body in front of the fuse box to the engine arm but what other grounds should be attached with the swap?
    /// MTech Belts ///
    S52 BUILD
    M3 VERT BUILD
  • raj
    • Oct 2013
    • 100
    There is a ground to the strut tower, a ground from the pan to the chassis, and another one from the hood to the chassis. There is also a small ground cable for the spark plugs and another for the fuel rail that goes to the engine lift bracket.
    • M3PO
      • May 2012
      • 537
      There is a ground that should go from the frame rail to the engine mount arm, one on the main harness that goes to the shock tower, an ignition coil ground that goes to the valve cover, and an injector harness ground that goes to the engine lift bracket.
