Flex Disc Query
  • Blake23
    • Jan 2017
    • 54
    Flex Disc Query
    Hey,
    The g260 I have has a larger flex disc than the flex disc on the back of my g240. This leads me to believe its a g260 from a late model 'eta' car. Is this correct?
    If so other than buying an 'eta' tail shaft which i'm having trouble finding in Australia is there a flex disc that would convert from the larger bolt pattern to the smaller bolt pattern or can i change the output flange from my g240 onto my g260?
    Thanks
    Blake
  • mtech325
    • May 2008
    • 569
    I think this is the piece you're looking for:
    • M3PO
      • May 2012
      • 537
      If you indeed have the "large guibo" Eta trans, an E36 328i or M3 driveshaft should work fine.
      • Blake23
        • Jan 2017
        • 54
        So I'm looking at the e36 328i driveshaft...
        This will bolt up to the small case diff? And I use the e30 csb?
        Thanks
        Blake
