e34 pan with built-in windage tray on s52?
  • mtech325
    • May 2008
    • 568
    Hi everyone,
    I'm in the middle of an s52 swap and I wanted to clarify whether it's OK to use the e34 oil pan with the built in windage tray. I came across this thread where the crank was hitting the m50b25 windage tray. From what I understand, this occurred because the pan was the variant without the built in windage tray, so the m50 style that mounts to the bottom of the block was used.
    I asked my friend with an s52 car if he used the pan with the built-in windage tray and he thinks so, and hasn't had any issues, but can't confirm. I test fitted the pan to the block and rotated the crank several times and didn't hear anything contacting but want to double check with people who have s52 cars if it's ok to use the pan I have.
    Thanks,
    Joey
  • HertE30
    • Jul 2014
    • 266
    Mine has the built in windage tray, no issues for me
    • BlackSpeed66
      • Apr 2008
      • 618
      Yep mine's doing fine as well. You can always do a test out of the car by installing it and turn the crank by hand to see if you hear anything making contact
      -Geno
      '87 325is (s52'd)
      '95 525iT
      '02 Range Rover 4.6 HSE
      '98 Disco 1
      • mtech325
        • May 2008
        • 568
        I ended up installing the pan, rotated the engine by hand and didn't hear anything, so all seems to be well. Can't wait to get the motor back into the car :)
        • 36brua
          • 689
          Agreed
          My CA legal M60 swap
          The happening in our garage
          • BlackSpeed66
            • Apr 2008
            • 618
            Good luck man! The s52 is a great engine in these cars!
            -Geno
            '87 325is (s52'd)
            '95 525iT
            '98 Disco 1
            • luckysnafu
              • Jun 2008
              • 262
              The built in tray e34 pan fit's fine. It's the e34 pan with the bolt in tray that doesn't clear the S52 crank, ask me how I know...
              M/S52 Wiring Diagrams
              Z3M S52 to late model 325i wiring diagram
              M52 to 318is wiring diagram
