Done me swap, the car runs sweet no issues apart from this strange problem where the car will only do it some times. It won't run.
Took the injectors out and they don't seem to be pulsing when this issues going on. I got this weird blow back through the intake when I tried to start it today. Also the fuel pump kept on whirring like it wasn't getting any fuel but had plenty. Sometimes it would whirr constantly and other times I turned the key on it would prime itself then stop like normal. On other random occurrences when turning the key on the injectors would squirt suddenly as soon as the key turned on... Im guessing thats what the blow back was, as the valves would be shut and the pressure from the injectors had no where to go but vent back through the air filter.
Im guessing its a bad connection some where and ive heard that you shouldn't solder the wires on theses, is that true? as I have soldered just about every splice.
Best answer gets a BJ
