help with id on a few connectors on my harness
  • hugh jass
    • 2220
    i have an obd1 e36 325 automatic wiring harness that i'm using in my swap. there are three connectors i am having a hard time identifying
    1. female connector with brn/yellow wire and brn/violet wire
    2. female connector brn/gry wire
    3. female connector with black wire and yellow wire. this one is by the O2 sensor plug
    the only sensors on the engine i haven't identified a connector on the harness for yet are the second coolant temp sensor and the oil pressor sensor on the oil filter housing.
    thanks for any help you can give.
    ______________________
    ex-Chief Operating Officer
    Blunt Tech Industries
    West Coast and Pacific Rim
  • hugh jass
    • 2220
    come on guys, doesn't someone here know what these are for?
    • DEV0 E30
      • Oct 2004
      • 8896
      How many pins are each? 2 or 3 pin wide?
      1) Oil sensor, if it's a 2 pin wide, plugs into the back of the oil filter housing. - 99% Sure.
      I'd know the other two if I was home, or had the E36 Bentley in front of me. Might be on here if you search through a few pages... It's easiest if you read the wiring diagram in the E36 Bentley, so you can recheck any you aren't sure about. I have pulled my M50 3 times in the past 2 weeks, I labaled my sensors with tape the 2nd and 3rd times.
      The temp sensor behind the first (closer to the back of the block) - (the 2 right next to each other) I thought had to be changed? I believe the plug that goes to it only has 1 wire. And my sensor for it only has 1 pin. If that makes sense.
      • aeryk7
        • Oct 2005
        • 616
        one by the 02 sensor plug i believe is the e36 reverse light plug
        253rwhp
        My Vids(OLD)
        http://www.youtube.com/user/aeryk7#p/a/u/0/hS4ZAzSdUdY
        http://www.youtube.com/user/aeryk7#p/u/2/C-0hnV2k_xU
        • Rev Engineer
          • Jan 2006
          • 162
          I think (1) is coolant temp to instrument cluster, (2) is oil pressure (should be brn/white), (3) is probably reverse light switch. My wiring spreadsheet might help you a little more:
          • matt
            • 3732
            Ya I think so too.
            • hugh jass
              • 2220
              thanks guys
              #1 is the for the coolant sensor for the dash gauge
              #2 is for the oil pressure sensor
              and based on the responses, #3 is the reverse light switch.
