Would it be ok to splice it into one of the ignition relays in the c101? Or would it cause problems from drawing to much power? or something like that.
Possible oil level (dynamic) sensor?
Ok, so to sum this thread up
If your x20 doesn't have the oil level dynamic wire(usually pin 10) then you will need to run a 3 wiries from the sensor in the oilpan to the e30 c101.
The 3 wires are:
1: Dynamic - Run this wire to pin 10 in the c101
2: Static - Run this wire to pin 2 in the c101
3: Ground - Run this to passanger side strut tower.
"It's like a koala bear crapped a rainbow in my brain."
R.I.P. Harry Goz aka. Captain Murphy
"My ride, My ride, she don't beg, steal, cheat, or lie,
My ride, My ride, and our relationship is classified."
Originally posted by Mike B. View PostYou need to wire in the E34 oil level sender separate from your E36 harness. It's three wires - two signal wires and a ground.
So you will need to wire in both the dynamic (E30 pin #10) and static (E30 pin #2) signals from the sender or it won't work properly.
