Hello,
m50TUB25 going into a 1990 318i, keeping the getrag 240 and also doing the m20 flywheel conversion. Going with the Porsche 944 brake booster as well.
Which master cylinder do I use wit the 944 booster (318i master cylinder or do I need to get an m20 specific brake booster master cylinder)? And I take it the slave is the same one used with the getrag 240?
Do I use OEM m20 flywheel bolts with the m20 flywheel/m50?
A LHD e34 throttle cable should work fine as well?
Id like to order the correct radiator hoses as well, so if anyone knows of BMW specific hoses (not necessarily OEM) I can use with a 318i radiator that would be great as well.
Part #'s much appreciated as well!!
I think that covers the last of the questions I have for what I need. Much thanks in advance. Hoping to put the order in this weekend.
