Hey guys, I have a few quick questions about my swap.The shell is a 87 325is.
1. I am using a puller SPAL fan but I have not decided on a radiator yet. I need one with a coolant temp sensor port in the side, and one thats on the cheaper side. Does anyone have any recommendations?
2. I am using an oil pan from a e34. Do I need the oil level sensor? To my knowledge the s52 dosent use one so it seems useless.
3. How does the 3.73lsd in the e30 work with a zf s52 combo?
4. Will a good tightening suffice on the oil pump nut of the s52? Or is a special nut/locktight required?
5. Any general recommendations for things to do to the engine prior to installation
Thanks for everyones help!
