Hi guys, im finishing my m52b28 swap on an early e30.
the cars was running "fine" (little rev hang), but since a 3 weeks, the cars shut down 5-15 minutes after start it.
to be exact, the fuel pump, begin to slowly make more noise than usual, then at WOT the car begin to lose power..if i continue at WOT the car shut off, but if i leave the foot from the pedal the car dont make shut off...
if i a press the acelerator again i can drive a few meters and then the same..
i have change the fuel pump for another brand new, the fuel pressure regulator and the crank position sensor for a brand new..
anyone had suffer the same problem?? thanks guys!
update:
parts changed:
-fuel pump
-fuel pressure regularor
-cam sensor
-crank sensor
update:
parts changed:
-fuel pump
-cam sensor
-crank sensor
