E30 M3 OBD1 S52 CEL Wiring
  • Sladek
    • May 2016
    • 228
    I'm having trouble with the wiring for a CEL in my swapped M3. they didn't come with one in the cluster and it'd be nice to see if there were any codes on the ecu to try and fix my running problem.
    I found the grey wire coming from the red label 413 DME but if I wire the ground side of the led to that and then run 12v switched to the other side the stomp test still doesn't work, and the TPS is brand new.
    what am I missing here?
