Brake booster vacuum problem= all 4 brakes stucks
  • babine810
    • Aug 2014
    • 19
    Soo my mechanic replace my leaking brake hose yesterday.now, when i press one time on the brake pedal, the compression work well. But after the 4 brakes is stuck like air come in but doesn't go out. When i disconnect the vaccuum hose from the brake booster . The brakes is now free and the brake pedal work well again? Did i have to replace the brake booster completely or i rebleed all ? Thanks
  • dude8383
    • Jan 2005
    • 10387
    Might need to adjust the clevis on the brake booster.
    • ThatOneEuroE30
      • Dec 2013
      • 8626
      Yea if this is a fresh swap its possible you didn’t get the clevis cut short enough and need to adjust it. What booster are you running? On my 944 booster i took off a decent amount and then re threaded it. No issues so far. Although my body guy did say it felt like my brakes were dragging but not sure i believe him cause i didn’t have any issues driving it to him.
      1991 318i 4dr slick top
      Mtech 2 turbo restoration
      • babine810
        • Aug 2014
        • 19
        I took from a renault like it said in e30zone and i did the little spacer in the master cyclinder. I think it parts of the problem.
        • babine810
          • Aug 2014
          • 19
          But i wondering why the brakes stuck?
          • ThatOneEuroE30
            • Dec 2013
            • 8626
            If the clevis pin is not adjusted right. It will result in the brakes getting stuck.
            • babine810
              • Aug 2014
              • 19
              Thank you! 🍻
              • almostacrayon
                • Nov 2012
                • 157
                The spacer just has to take the space difference between boosters.
                The length given on e30zone is just a rough estimate (what worked for that user).
                Mine was only 10mm. That might be your issue?
