Throttle & cruise cable question
  • RenaissanceMan
    • Aug 2004
    • 237
    Going to be using the s52 throttle body in my E30 s52 OBD2 swap. Was wondering if I can just replace the current throttle and cruise control cables with the E36 M3 versions? Will they swap out fine on the E30?
    Sent from my VS995 using Tapatalk
    '90 325is/S52
    '76 2002
    '74 2002tii
    '06 325i sedan
    '05 X5 3.0i
    '86 Alfa Spider Veloce
  • raj
    • Oct 2013
    • 100
    You will need the E34 throttle cable, #35411160609. Not sure about cruise control.
    • BlackSpeed66
      • Apr 2008
      • 624
      The answer is slightly different depending if you're going OBDI or OBDII. OBDI is a bit easier as I believe you can use the e34 cable as previously mentioned. OBDII requires a little bit more work. I've got a post around here somewhere from when I converted mine (I'm running OBDII).
      -Geno
      '87 325is (s52'd)
      '95 525iT
      '95 Jaguar XJR-6
      '02 Range Rover 4.6 HSE
      '98 Disco 1
      • RenaissanceMan
        • Aug 2004
        • 237
        Thanks for the reply. This is exactly the information I was looking for, as I am converting to OBD2. I already have an E34 cable on my car right now with the M50 OBD1 set up, but I was trying to make sure I understand the correct way of connecting throttle and cruise control in this new OBD2 environment. The end of the E30 for cable has a long solid metal piece that will not curve around the throttle body spring like it would on an s52. This is why I was curious to know if you could just use an s52 throttle cable on an OBD2 conversion?
        '90 325is/S52
        '76 2002
        '74 2002tii
        '06 325i sedan
        '05 X5 3.0i
        • BlackSpeed66
          • Apr 2008
          • 624
          Take a look at my post #15. Hope you're handy w/ a Dremel :p
          -Geno
          '87 325is (s52'd)
          '95 525iT
          '95 Jaguar XJR-6
          '98 Disco 1
          • RenaissanceMan
            • Aug 2004
            • 237
            Take a look at my post #15. Hope you're handy w/ a Dremel [emoji14]
            https://www.r3vlimited.com/board/sho...throttle+cable
            Thanks!!
            '90 325is/S52
            '76 2002
            '74 2002tii
            '06 325i sedan
            '05 X5 3.0i
