Question about running lossless and purge valves
  • RenaissanceMan
    • Aug 2004
    • 236
    Those of you running OBD2 setups, did you have to have a running lossless or purge valve installed? Buttoning up the final elements of my swap and was curious if the absence of either of these components would result in a CEL or running problems? I have a plug in my converted harness for the running lossless valve but I don't think I have one for the OBD2 purge valve. Is this similar to your harness setups? Thanks for any insight-
    Sent from my VS995 using Tapatalk
    '90 325is/S52
    '76 2002
    '74 2002tii
    '06 325i sedan
    '05 X5 3.0i
    '86 Alfa Spider Veloce
