M50 sawap
  • Olymbios
    • Dec 2017
    • 1
    M50 sawap
    Have just swapped a M50 e34 engine in to my 1.8 auto tourer. It cranks but to spark or fuel tested bits that I can think of but can't get my head round it. Any help would be much appreciated. Cheers
  • sweet3
    • Oct 2012
    • 752
    Are you using a red label or silver label ECU?
    Do you have a ground strap from the chassis to the engine mount arm?
    Have you taken the fuel lines off and Jumped pin 30 and 87 on the fuel pump relay?
    Make sure you have your fuel lines on correctly. They can often be mixed up.
    PNP Adapter Harness Wiring for M52TU, M54, S54, M60, M62, M62TU, S62, M50, S50, M52, S52 & MORE
