E30 m52b28tu swap
  • ArmandoE30
    • Jan 2018
    • 1
    E30 m52b28tu swap
    Hi guys, I know there has probably been more than one discussion about this already, but I would really appreciate if you could help me out with this, it's driving me crazy.
    Been searching for this info for days now and I struggle to find a clear description.
    So I'm doing a m52b28tu swap into my 1989 e30 and I'm stuck at hooking up the harnesses.
    I'm have Siemens ms42 dme.
    As I understand I need to run wires from
    4pin connector
    8pin connector
    Double 2 pin connector
    And x60004 connector
    To c101 connector
    - if someone would be so kind to map out what wires I'm using from connectors mentioned above and exactly where they are going(I.e. x60004 connector pin 10 to c101 pin 13) I would be in your debt forever.
    Many thanks in advance
    Armando
