So I got the m50 swap done in mike's [the fast one!] and it has a horrible driveline vibration. Its chewing up guibos. Apparantly it was like this before, all of a sudden it developed a vibration with the m20 still in it. I know that one of the motor mounts broke with the m20 in it, and that that could be a possible cause (trans mounts probably werent good, but unknown condition).
The guibo was trashed when we pulled the motor. Okay, bad guibo, replace it. (installed m50) I drive the car, dont notice anything. He drives it and says there is a bad vibration. I drive it and confirm. Center support bearing was questionable, so replace, why not... Some difference, but still there under acceleration. He gets under the car today and new guibo is trashed.
Im thinking its because of the transmisson mounting position. ie, the 10 degree shift and using the 320 mounts. I noticed that the trans was sitting a little higher than I thought it should be. I was able to tweak it back to a suitable position, but I dont know what else it could be.
Could a bad driveshaft (balanced or misaligned) make such a bad vibration. I've got the u-joints phased correctly, but they dont seem to line up perfectly, and they dont no matter if i go to the next spline. I also know the shaft has been split and probably not put back together in the same place. Should he consider another driveshaft? Why would it happen with the m20 still in all of a sudden, new mounts (motor and trans) put in, so I cant really blame them.
