Lopey Idle (under 1000 RPM) When Car Warms Up
  • cokeisgood00
    • 152
    I'm looking for some m5x gurus. I have a m50 swapped e30. The engine is a 91 m50 non vanos with a 402 silver sticker ECU.
    I'm having a lopey low idle issue. When I first crank the engine cold it idles perfect. I watched it warm up yesterday with a multi meter on the CTS and at 0.79 ohms (halfway or so to normal temp) exactly it started it's poor idle.
    With its warm you can unplug the MAF and it idles fine, then hunts for a second, then back to fine. Reconnect the MAF and it's lopey again.
    If you introduce a large vacuum leak (unplugging the ICV hose at the boot) it idles beautifully until you plug it back in.
    Uncapping the oil fill does nothing in regards to idle speed while the engine is running.
    Here's what I've done. I've tested the MAF per the Bentley and it checked out OK. I've pulled the ICV and cleaned it and it moves freely when shaken and hums with the key in ON. I replaced the CTS yesterday because why not. I've sprayed brake clean at every possible place looking for a vacuum leak with no luck.
    86 528e b25
    00 528i
    95 525iT
    88 325is m52
    86 325es m50
  • cokeisgood00
    • 152
    Bump: AFRs under different idle conditions.
    Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.
    86 528e b25
    00 528i
    95 525iT
    88 325is m52
    86 325es m50
    • MrBurgundy
      R3V Degenerate
      • Mar 2012
      • 5599
      You should really get a smoke test done, also a shit o2 sensor can cause similar problems
