M50 and Z3 rack PS Hose options
  • TENSE
    • Jan 2015
    • 25
    Hey guys im about the do the z3 swap on my M50 E30. Heard guys using different hoses to to accommodate the different rack.
    Anyone who has done this swap. What hoses did you use? part numbers?
  • mtech325
    • May 2008
    • 572
    I used all m20b25 325i lines on my rack swap 24v car. High pressure line needed slight bending of the fittings by hand to work properly, and the low pressure lines needed trimming up top because the reservoir mounted on the motor arm sits closer to the rack than it would for the e30's stock reservoir location.
    • Metallated
      • Dec 2016
      • 1074
      I can confirm what mtech325 is saying, I tried using e36 lines but they don't fit very well at all.
