E30 S50B30 Euro conversion, wont start
  • finlay007
    • Sep 2016
    • 1
    hi folks
    ive just converted my e30 to S50 but wont start, the only pin with power on the E30 20 pin plug, when ignition on, is pin 13( fuel pump) no power to ecu, starter rely, ignition etc etc
    does anyone have any thoughts that can point me in right direction ?
    does the E 30 have a factory imob that needs bypassed ? only thing that doesnt add up is the e30 had a m52 fitted when i bought it that started on the key with no imob or anything
    any help appriciated
    cheers
    Finlay
  • haaken675
    • Sep 2016
    • 601
    What year car do you have? It's possible that the c101 diagram you used to splice into your engine harness doesn't match up with your cars harness.
    • nrubenstein
      • 3148
      The E30 does not have an immobilizer from the factory. However, it's possible that the M52 swap had EWS retrofitted.
      Does the car crank, or is there no start signal at all?
      2002 BMW M3 Alpinweiß/Black
      1999 323i GTS2 Alpinweiß
      1995 M3 Dakargelb/Black
      - S50B32/S6S420G/3.91
      1990 325is Brilliantrot/Tan
      1989 M3 Alpinweiß/Black
      • Mwishlist
        • Jul 2013
        • 505
        Actually the 10 button OBC does have an immobilizer and I ran into that issue with my S52 swap, since I had installed a euro clock. It would crank but not fire. But that seems super rare, I only found one other person ever had that same issue.
        We need more details like nrubenstein said, does it crank but not fire, not crank at all, power to the gauges, etc.?
        Thank god, R3V was getting boring since the ginger kid wrecked his car. - Stonea
        • pazi88
          • Sep 2015
          • 584
          If the engine doesn't crank and/or no power to ecu, it's just faulty wiring, because those come directly fron ignition switch. Just use multimeter to hunt down where the problem is.
          • WAM3
            • Aug 2016
            • 28
            how did you wire the new engine? need more details to assist. I have the euro s50b30 schematic if you need.
            • Adrian_Visser
              • Jun 2006
              • 2823
              You need to verify your pinout on the c101 engine harness plug. The Euro motor is different than the North American ones. What year car did the motor come from and what year/model e30 did it go into?
              '89 Alpine S52 with goodies
