OBD II S52 swap no start
  • bmwlover
    • 8
    Good morning,
    Just want to know what you think. I have a 1990 325i, S52 swap. I bought the harness from Markert Motor Works, and the DME from TRM. When I turn the engine over I do get fuel, checked the Schraider Valve and there's fuel. I know the injectors work because I pulled the plugs and they are clean but smell of fuel. It will turn over, but nothing. I've noticed that I can turn it over without depressing the clutch pedal? I've jumped the clutch connector and turned it over but still nothing? Any help or input would be greatly appreciated.
  • DesertBMW
    • Aug 2011
    • 1043
    Basic procedure is first read BMW factory codes. Second check if there is spark, check if there is injector spraying, check compression.
