Cam Sensor to Harness wiring
  • NEOe30
    • Jun 2016
    • 415
    Hey all,
    While trying to organize my wiring in the engine bay to clean things up a bit I tugged a little too hard and the wiring came undone for the cam sensor, looks like the PO swapped the sensor or something, not sure why it's like that, but it did use to run just fine. I feel like it should be a simple signal-ground-shield wiring scheme, but I just can't figure it out. Maybe someone can help... What goes where!?!
    Harness Side
    Sensor Side
  • ZekeTheSneak
    • 1562
    obd1 or 2? That is the wire colors for obd2. That third wire a red wire? If it’s not then maybe obd1 is different colors and the connector is from obd2.
    • NEOe30
      • Jun 2016
      • 415
      Colors from the harness side are yellow/black/shield
      Colors from the sensor side are brown/black/red&green
      • E30335i
        • Feb 2014
        • 1035
        Yellow black shield is knock sensors isn’t it?
        • NEOe30
          • Jun 2016
          • 415
          Mines out of an e34 so pretty sure OBD1, it’s a nonvanos. Should mention I’m running mega squirt 3x. This diagram here shows cam position as black yellow shield...
          • NEOe30
            • Jun 2016
            • 415
            • pazi88
              • Sep 2015
              • 584
              Well that sensor side plug is not for m50 non vanos cam sensor. That I'm sure. Even the connector is wrong type. That is female connector, but the cam sensor should have male connector. The harness side wires match the nonvanos wiring harness. Black and yellow are the vr sensor signal wires.
              • NEOe30
                • Jun 2016
                • 415
                So what you’re saying is that the plug is not the correct one? I guess that would make sense. I have no clue where the right one may be.. any idea if I can source such a plug online?
                • pazi88
                  • Sep 2015
                  • 584
                  No idea where to get exact right type. But those are minitimer connectors, which can be bought easily. You just may need to "adjust" the plastics that prevent wrong type of connector to be plugged in. (Like mixing IAC and cam sensor connectors)
                  There is also possibility that the ms3x uses for example hall type cam sensor from m50tu instead of the vr sensor from non-vanos m50. And if I remember correctly, it has that kind if plug.
