Hey everyone looking for some insight to my issues with this swap. I have an s50b30 from a 95 m3 into my 89 e30.
Now using the 413 red label DME idle is steady (750ish) until after a few minutes then it will rev itself to about 1200 rpm then drop and throws an oxy sensor code pulled from my Peakse reader, (note stomp test is no worky) After the code the car runs like absolute crap lots of hesitation, and I noticed its fouling my plugs. (blacks them out, not wet)
This is consistent, it does it every single time.
I tried another DME a 506 sliver label with a Eurosport chip that is supposedly for stock S50. It idles like shit, its lumpy like if i had a big cam. If i disconnect the ICV it runs fine after. (assume this means it defaults into open loop?) I still get the same Od code from the Peakse and same result.
Things ive done so far:New o2 sensor, New maf, new fpr, rebuilt injectors (stock green tops), ebay headers, CPS sensor tested, Compression test was near perfect, smoke test showed a leak, but already replaced the hose, Timing has been double checked, cleaned the ICV.
Engine is a stock S50, used getrag 260 with M20 flywheel and clutch, used a garagstic wiring harness adapter.
Im not sure where to look next, can anyone please give me some suggestions?
