Acceleration *Videos*
  • Stu Mc
    • 4083
    Is that the stock rad. overflow tank on the 6-throttle car?
    It looks just like a late model M20 tank !
    • morerevsm3
      • 108
      yes, stock cooling system
      12.921 @ 106.48mph - N/A E36 3.0L daily driver
      • shellback
        • Nov 2005
        • 99
        i think i'm going to be sick...
        • Mike325
          • Mar 2006
          • 3685
          So what is the 0-60 mph on the e30? Looks like 4 seconds?
          Originally posted by Kershaw
          • KangamangusDriver
            • Aug 2005
            • 1870
            Time to upgrade the M50!!!
            • Stu Mc
              • 4083
              Interesting about the cooling system on the Euro cars. I wonder why they didn't use the same rad/overflowtank setup as US cars. Anyone know? Clearence problems?
              Do it man, go to a 3.0 high c/r when your bottomend gets tired (though that will probably be a long time).
              • aeryk7
                • Oct 2005
                • 616
                Acceleration probably is around 4.5 or so if i would get full traction , right now i am stuck in a dilema . Should i do wider rims or should i throw on r 225/45/14 R-compounds.
                253rwhp
                My Vids(OLD)
                http://www.youtube.com/user/aeryk7#p/a/u/0/hS4ZAzSdUdY
                http://www.youtube.com/user/aeryk7#p/u/2/C-0hnV2k_xU
                • 1990m3
                  • 1180
                  yeah, that is the stock cooling system for all euro 6-cylinders, but the euro ///M has the larger radiator like the US cars.
                  That radiator looks to be the same as a US 318is that I have sitting around, might give it a try in a few weeks. Should be good for the winter anyway.
                  • morerevsm3
                    • 108
                    it is standard, original euro M3 radiator and overflow bottle, been in car since new, it is larger(thicker) than US M3 radiator, probably looks a little different because I removed the shroud when I removed the viscous fan
                    • 1990m3
                      • 1180
                      it's standard? When I searched the ETK it showed the euro e36 m3 radiator at 550m across and all other 6-cylinders I checked at 440mm across. 550mm is the width of the e30 frame rails, you can't fit a 550mm with coolant tank on it in an e30. At least I don't think you can.
                      I only checked a euro s50b32 motor though, maybe the euro s50b30 has a smaller radiator??
                      • morerevsm3
                        • 108
                        here is my VIN no. you can check ETK if you wish
                        WBSBF9208OEA66643
                        cheers, Alan
                        • 1990m3
                          • 1180
                          thanks. I love the idea of a smaller radiator with integrated overflow tank, it looks much tidier. It's just a matter of whether or not it will cool. Sounds like it will be fine. Probably gets a lot hotter in australia than it does here in Wisconsin.
                          I'm confused. Here is the diagram shown for your VIN number. Note the radiator has a remote reservoir and is 550mm in length
                          http://www.realoem.com/bmw/showparts...02&hg=17&fg=05
                          • morerevsm3
                            • 108
                            looks the same as my radiator and overflow reservoir to me, remote reservoir is top right corner
                            • 1990m3
                              • 1180
                              ooops, I thought you meant that you had the radiator with the overflow tank built in, the smaller radiator.
                              • Rev Engineer
                                • Jan 2006
                                • 162
                                What format are these videos in? The files I downloaded don't have an extension.
