I decided to build this S52 to put in a e30 after seeing a couple of FB posts of guys running mid to high 12s with S52 swapped cars. Many claiming that s52 swapped cars are faster than M60/62 swaps. That and S52s have tons of cheap aftermarket modifications unlike the bmw V8s.
My goal is to build an S52 using only junkyard parts and used parts from a few of my BMW dismantling friends. The budget is $2500 which seems to be the going rate for a used S52. Even if I go overbudget a little it will still be worth it to me having a freshly rebuilt engine. There is not really have a timeline for this as I don't have a e30 to put it in yet. I find I can get better prices on parts when I'm more patient and have the time to search around.
Here is the recipe.
- M50 or M52 engine block bored to 86.4mm
- S52 pistons and rods. New rings of course.
- M54B30 crankshaft. These are plentiful in junkyards, but time consuming to pull.
- M52 cylinder head. I plan on upgrading the valve springs for some hot cams.
- e34 oil pan, pickup tube, and dipstick. Not as easy to find in junkyards and very time consuming to pull.
Here is what I have so far,
S52 pistons and rods, I paid $200 for these.
Typicall wear, but no gouges or cracks in the ring lands.
I pulled this M52 head from a junkyard a year ago. I pulled the valve cover and it was immediately obvious that it had been in a machine shop recently. I paid $97 for it.
The new valve guide seals were a dead give away.
And the surface finish on the deck were excellent. Clearly it was resurfaced not that long ago. Don't mind the crud on it, it's been in my shed for a year.
I've got a lead on a M50 block for $75 next week. Hopefully the guy comes through, I really don't want to pull and disassemble a M50 in a junkyard, plus LKQ wants $200 for a bare block.
More updates to follow as I acquire parts.
Sent from my SM-G960U using Tapatalk
Here is the recipe.
