Wiring for check engine light & diagnostic port
  • Mk2dude
    • Feb 2018
    • 11
    Ok I have 1986 325E with a 95 m3 s50 obd1 swap. How do I wire up check engine light. On the c101 plug, pin 12 is empty. On the x20 there’s pin 8 [grey wire]. Do I pull the cluster and tap into green/white wire with pin 8 from x20?
    Also how do I wire up diagnostic port. Is it pin 16 [white/black] from c101 to x20 pin 17 x20?. With both things wired up, will it allow me to scan for codes through diagnostic port from e36. I have a Peake scan tool, but there’s no power at diagnostic port.
