M50nv revs to 3k and feels like 2step
  • razo-s.supra
    • Dec 2009
    • 124
    searched for hours and found nothing like what I am experiencing. Cold or hot does not matter. When I rev the engine under load or not it will rev to 3k and bounce like it has 2 step. If I keep on the throttle it will rise to 5kish and resume the "2step" behavior. I've tried a new o2 sensor, new filter, vac leaks, cleaned the maf sensor and the problem persists. Any takers? My cel is not functioning as it never ever comes on even briefly when starting.
    https://youtu.be/50RWCxsWblE[/url<br...be/50RWCxsWblE
  • TeXJ
    • 1914
    My car does this exact same thing...been in the shop for 3 months. I tried to find the cause but i'm retarded with electrical issues.
    Basically, I'm just subbing to see what is found.
    1990 325is
    m52b28
    3.73lsd
    g260 (1987 325is 5spd tranny)
    • Striebels
      • Nov 2018
      • 7
      I’d swap Ecu’s with a friend, I’ve seen weird things before.
      • razo-s.supra
        • Dec 2009
        • 124
        Junk yard diving time
        • ZekeTheSneak
          • 1562
          Drive it around and it will stop. Do you have a check engine light? Mine does it too and my solution is going obd2....
          • Striebels
            • Nov 2018
            • 7
            Also I’d look into replacing your throttle position sensor.
            • Red88
              • Nov 2008
              • 1161
              Coils!
              Have you made a purchase from www.blunttech.com recently?
              sigpic<< wrecked
              • razo-s.supra
                • Dec 2009
                • 124
                SOLVED! for some weird reason I replaced my tps with a "known" good one. Nothin. Gave in and bought a new one and voila. Still got that over heating problem. Ugh this m50 and air bubbles are like gum on my shoe
