Vacuum line and fused wires OBD2
  • grizstiles
    • Feb 2017
    • 13
    Alright I've checked the Bentley and just about everywhere else, hooking up the fuel lines to my s52 and I cannot find where the vacuum line goes from the fuel pressure regulator onto the engine. I'm assuming it goes onto the intake manifold but I can't see where. Most people use the m50 manifold but I'm trying to keep as many of the sensors I can. And also there are plenty of threads that talk about wiring the x20 and the c101 together but I can't find a thread where they explain the other wires that need to be fused/ get power. The only one I kinda get is that there is a wire from the main relay that gives power to the ecu (I believe it's a 20amp fuse).
  • pazi88
    • Sep 2015
    • 584
    Vacuum line goes under the intake. Close to thorttle body there is few vacuum ports.
    And no need to do other wiring. X20 to c101 and main battery power plus ground is enough.
