I've been working on my wiring harness for my M52B28 OBD2 swap the last few days. The motor will be going into my M40 e30 Touring that is a '94 build.
The main X20 to C101 connection conversion has gone well from the info I've found through the web/forums. However I have some questions as my harness/engine was from an Automatic e36 (6/96 build). The harness has 3 round connections:
My question is regarding removing the wiring to the 2 extra connectors. I cut off the Automatic computer connector and traced all wires back to these 2 connectors and removed them. However I was left with a few extra wires:
The excess wires from the two connectors to the DME i've just cut, shrink tubed & tucked away in the main wiring casing. Is that ok to do? Can i do the same for the 2 other wires from the DME?
I searched quite a bit but have been unable to find anything
much appreciated
Happy Holidays!
- The main connector plug that i've switched to C101
- Automatic Transmission connector
- ASC? connector - i'm not 100% sure what this connector is for as most of the dyi on the web for autos show 2 connectors only
- 5 wires from the smaller connector that trace back to the DME
- 4 wires from the larger connector (auto) that trace back to the DME
- 2 wires, from the auto computer to the DME. one brown, one double black & yellow twist.
much appreciated
Happy Holidays!
