Just converted my s52 to OBD2. Fired it up thursday night and it drove fine, Short drive but took it too redline no problem. Check Engine light came on from the start.
Today I finished wiring up my obd2 port and my bluetooth adapter came in. I plugged in the torque app pro and cleared the CEL light. (CamPS, Maf,) Went for a drive and it is stumbling under load. Barely wants to rev out. I didn't push it but drove it on my usual 5 mile loop to see if I could get a CEL. Got a CEL for cam position sensor so I swapped it out with another unknown used one. I clear the CEL using the app.
I go for a ride now and same hesitation but no CEL this time. Should I keep driving it until I get a code? I can limp it around just fine.
I am running NGK BKR6E spark plugs. They look fine.
Bosch OBD2 coils, the two hole variant. I do have plenty of obd1 coils I could try.
The Crank Postion sensor is the rear mounted, recall updated version with the extra wire loom.
Wiring was done by me and I was very thorough and traced every wire, labeled every connector.
