smoke with s52 obd1 conversion.
  • Lenwood
    • Mar 2012
    • 100
    getting smoke on start up and acceleration. how to prevent? oil catch can? anybody have an insight on this they can provide?i know bmw had an oil seperator on the obd2 setup.
    1989 325ix(sold)
    1989 325i sedan s52 powa (current)
  • ZekeTheSneak
    • 1562
    Oil burning or coolant? what color is it? How is your current crank case vent set up? How many miles since swap?
    • e30austin
      • 15382
      Change to 5w30 Liquimoly and see what happens. I've had a few cars that it has significantly helped with oil consumption/smoking on.
      • ZekeTheSneak
        • 1562
        is that bmw LL01 austin? Just curious. What oil you running and weight lenwood?
        • Lenwood
          • Mar 2012
          • 100
          Re smoke
          Problem pretty much solved. Have an e34 dipstick. Changing over to an s52 dipstick with vent line for catchcan and crankcase. Should solve the smoke problem
          1989 325ix(sold)
          • ZekeTheSneak
            • 1562
            How are you routing that? Also that dipstick won't fit in the oil pan. You will have to cut the drain tube off and weld it to the e34 tube.
            • Lenwood
              • Mar 2012
              • 100
              re
              got it zeke, between the 2 ill get it to work
              1989 325ix(sold)
              • King Mufasa
                • Sep 2012
                • 530
                m54 swap time
                • Wanganstyle
                  • 2828
                  There is no difference mechanically in functions between a s52 and a M50b25 with vanos.
                  CCV is not something that prevents oil burning - its actually known to burn alot of oil when it fails.
                  IF you have an obd1 converted anything that smokes you should leak down the motor. I would hope that @ the bmw dealership there is a tech who has a leak down tester and knows how to use it.......
                  if the motor is burning oil its either burning oil from the valve stem seals or the piston rings; the S52 is known for burning oil from dead piston rings /worn pistons - Yes the pistions wear, no there is no magical way to fix this besides changing piston rings and or changing pistons to new.
                  How do I know? been there done that (many times); worn out s52 = burns oil..... sometimes a cloud.
                  my honda insight with almost 400k does not burn any oil......at all. or leak any at all
                  Leak it down. then you will know
                  asking the interweb to diagnose your problem does not help you.
