Fuel line quick disconnect fitting on e39 rail
  • Codym42
    • Mar 2013
    • 611
    I need to replace my fuel lines from the fuel rail to the chassis with something better. Has anyone used the quick disconnect to barb fittings (Dorman 800-080)? I'd rather not spend $80 on new BMW fuel lines that I'll have to cut anyway. I like the idea of using a barb fitting with brand new 8x13mm fuel hose straight to the chassis hard lines. I'm using a fuel rail with integrated FPR from a '97 528i. I've never used quick disconnect fittings before so I'm a little unclear on how to do this properly or if those Dorman fittings will even work on a BMW line.
    '90 325i - 5 speed coupe
    '05 330ci 6MT ZHP
  • AndrewBird
    The Mad Scientist
    • 11898
    Why not just slip the fuel line onto the fuel rail tubes and secure with a clamp?
    • Codym42
      • Mar 2013
      • 611
      Usually if there's not a barb, the rubber lines are easy to slide off even with a clamp. I may try it anyway.
      '05 330ci 6MT ZHP
      • The Dark Side of Will
        • Jun 2010
        • 2796
        The Dorman 800-080 is made for nylon tubing.
        For use with rubber hose try 800-782 instead.
        5/16 In. Fuel Line Connector, Straight To 5/16 In. Barbed
        The page says it's 3/8", but it's actually 5/16". I ordered one and was surprised.
        Also note the double barb... it can be double clamped. STRONGLY recommended for the supply line.
        • ZekeTheSneak
          • 1562
          That's awesome. I'm rocking e36 fuel lines with the quick disconnect. They came with the motor. New ones are 100 bucks iirc....
          • Codym42
            • Mar 2013
            • 611
            That's great to hear! So, these are working for you with no problems? If so, I'm going to order some.
            Looks like you're in the same boat as me. The BMW fuel hoses with the quick disconnect are stupid expensive!
            '05 330ci 6MT ZHP
              • Jun 2010
              • 2796
              I'm not using it yet... like I said, I thought I was ordering 3/8 and was surprised :p
              The 3/8 version is only available with a 90 degree bend, so I'm organizing my hoses around that.
              This is for a non-BMW app.
              • Codym42
                • Mar 2013
                • 611
                I just ordered the Dorman 800-120 (which are actually supposed to be 5/16") along with a set of Lisle 39400 quick disconnect tools on Amazon. I'll update on how well this works.
                '05 330ci 6MT ZHP
                • Codym42
                  • Mar 2013
                  • 611
                  Just to update, the Dorman 800-120 connectors work great! I've driven about 75 miles so far and no leaks! I used these and some brand new 8x13 fuel hose and everything was good.
                  '05 330ci 6MT ZHP
