Hey guys! I am currently doing the m52tu swap. I have put my e34 oil pan on it and the power steering pump inlet hose fouls it. What are my best options of getting around this? Also, wondering if a e38 ms42 loom will work and reach the proper ECU location correctly. Any help is appreciated. Cheers
M52TU Swap help!
Are you sure you are have m52tu the twin vanos one?
I have this issue as well with a z3 m52b28 engine. You will have to extend the bracket, which i found somewhere on this forum (you have to search) and use a longer belt.
Else maybe you can swap to another power steering pump.
Cheers
Thanks for your reply. 100% certain as it is a dual vanos from an e46. Can I used a bracket from another model possibly?Are you sure you are have m52tu the twin vanos one?
Cheers
