Matching Cam / Crank Sensor wires to harness help.
  • 540ig5
    • Nov 2013
    • 20
    I have non-vanos M50 which i'm in the process of putting the wiring harness on. I have all the plugs matched up with the exception of the Cam and Crank sensor. Are these interchangeable as far as the wiring harness goes?
    The two plugs I have on the harness side have the exact same wire color combination, so I don't really know which one should go to the Cam sensor and which one to the Crank sensor. Any help would be great, thanks.
  • pazi88
    • Sep 2015
    • 584
    Plug those in and check if engine starts. If not, swap those and try again.
    • AndrewBird
      The Mad Scientist
      • 11897
      This.
      I don't know why they used the same wire colors, but they did. You could check for continuity at the ECU connector to figure it out though. Would be easy if you have the harness out of the car.
